Sound Settings (Alarms node)
When you configure sound settings, specify the following:
Name
Description
Sounds
Select the sound to be associated with the alarm. The list of sounds contains a number of default Windows sounds. You can also add new sounds (.wav or .mp3).
Add
Add sounds. Browse the sound file and upload one or several .wav or .mp3 files.
Remove
Remove a selected sound from the list of manually added sounds. Default sounds cannot be removed.
Test
Test the sound. In the list, select the sound. The sound plays once.
