Smart map
Note
This feature is only available in certain XProtect VMS systems. For more information, see the product comparison chart: https://www.milestonesys.com/products/software/xprotect-comparison/.
In XProtect® Smart Client and in XProtect Mobile, the smart map feature lets you view and access devices at multiple locations around the world in a geographically correct way. Unlike maps, where you had a different map for each location, smart map gives you the big picture in a single view.
The following configuration of the smart map feature is done in Management Client:
Configure the geographic backgrounds that you can choose for your smart map. This includes integrating your smart map with one of the following services:
Enable Bing Maps or Google Maps in XProtect Management Client or in XProtect Smart Client
Enable editing of smart maps, including devices, in XProtect Smart Client
Position your devices geographically in XProtect Management Client
Set up your smart map with Milestone Federated Architecture
