Server Logs tab (options)
On the Server Logs tab, you can specify settings for the system’s management server logs.
Name | Description |
Logs | Select the log type that you want to configure:
Settings | Disable or enable the logs and specify the retention period. For System logs, specify the level of messages that you want to log:
For Audit logs, enable user access logging if you want the system to log all user actions in XProtect Smart Client. These are, for example, exports, activating outputs, and viewing cameras live or in playback. Specify:
Settings | Disable or enable the logs and specify the retention period. Allow 2018 R2 and earlier components to write logs. For System logs, specify the level of messages that you want to log:
