Move devices from one storage to another
Note
When you select a new location to store recordings, the existing recordings will not be moved. They will remain in the current location, with the conditions defined by the configuration of the storage they belong to.
  1. In the Site Navigation pane, select Devices.
  2. Select the relevant device in the Overview pane and select the Recording tab.
  3. Click Select under Storage to select a recording storage for your devices to record in.
The recordings will archive according to the configuration for the storage that you select.
