Microphones (Devices node)
Microphone devices are added automatically when you add hardware to the system. They are by default disabled, so you must enable them before use, either as part of the Add Hardware wizard or afterwards. Microphones that are part of a camera do not require separate licenses but independent microphones are considered separate devices and therefore require a separate license. You can use as many microphones as required on your system.
You can use microphones completely independently of cameras.
The system comes with a default start audio feed rule which ensures that audio feeds from all connected microphones are automatically fed to the system. The default rule can be deactivated and/or modified as required.
You can configure microphone devices on these tabs:
  • Info tab
  • Settings tab
  • Record tab
  • Events tab
