Metadata (Devices node)
The system comes with a default start feed rule which ensures that metadata feeds from all connected hardware that supports metadata, are automatically fed to the system. The default rule can be deactivated and/or modified as required.
You can configure metadata devices on these tabs:
  • Info tab
  • Settings tab
  • Record tab
