Management Client Profiles (Client node)
Note
This functionality is available in XProtect Corporate only.
Info tab (Management Client Profiles)
On the Info tab, you can set the following for Management Client profiles:
Component | Requirement |
Name | Enter a name for the Management Client profile. |
Priority | Use the up and down arrows to set a priority for the Management Client profile. |
Description | Enter a description for the profile. This is optional. |
Roles using the Management Client profile | This field shows the roles that you have associated with the Management Client profile. You cannot edit this. |
Profile tab (Management Client Profiles)
Note
Available functionality depends on the system you are using. See the complete feature list, which is available on the product overview page on the Milestone website (https://www.milestonesys.com/products/software/xprotect-comparison/).
On the Profile tab, you can enable or disable the visibility of the following elements from the Management Client's user interface:
Navigation
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the various features and functionality located in the Navigation pane.
Navigation element | Description |
Basics | Allows the administrator user associated with the Management Client profile to see License Information and Site Information. |
Remote Connect Services | Allows the administrator user associated with the Management Client profile to see Axis One-click Camera Connection. |
Servers | Allows the administrator user associated with the Management Client profile to see Recording Servers and Failover Servers. |
Devices | Allows the administrator user associated with the Management Client profile to see Cameras, Microphones, Speakers, Metadata, Input and Output. |
Client | Allows the administrator user associated with the Management Client profile to see Smart Wall, View Groups, Smart Client Profiles, Management Client Profiles and Matrix. |
Rules and Events | Allows the administrator user associated with the Management Client profile to see Rules, Time Profiles, Notification Profiles, User-defined Events, Analytics Events and Generic Events. |
Security | Allows the administrator user associated with the Management Client profile to see Roles and Basic Users. |
System Dashboard | Allows the administrator user associated with the Management Client profile to see System Monitor, System Monitor Thresholds, Evidence Lock, Current Tasks and Configuration Reports. |
Server Logs | Allows the administrator user associated with the Management Client profile to see system, audit, and rule-triggered logs. |
Access Control | Allows the administrator user associated with the Management Client profile to see Access Control features, if you have added any access control system integrations or plug-ins to your system. |
Details
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the various tabs for a specific device channel, for example the Settings tab or Record tab for cameras.
Device channel | Description |
Cameras | Allows the administrator user associated with the Management Client profile to see some or all camera-related settings and tabs. |
Microphones | Allows the administrator user associated with the Management Client profile to see some or all microphone-related settings and tabs. |
Speakers | Allows the administrator user associated with the Management Client profile to see some or all speaker-related settings and tabs. |
Metadata | Allows the administrator user associated with the Management Client profile to see some or all metadata-related settings and tabs. |
Input | Allows the administrator user associated with the Management Client profile to see some or all input-related settings and tabs. |
Output | Allows the administrator user associated with the Management Client profile to see some or all output-related settings and tabs. |
Tools Menu
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the elements that are part of the Tools menu.
Tool Menu option | Description |
Registered Services | Allows the administrator user associated with the Management Client profile to see Registered Services. |
Effective Roles | Allows the administrator user associated with the Management Client profile to see Effective Roles. |
Options | Allows the administrator user associated with the Management Client profile to see Options. |
Federated Sites
In this section, decide if an administrator user associated with the Management Client profile is allowed to see the Federated Site Hierarchy pane.
