LPR tab (roles)
If your system runs with XProtect LPR, specify the following permissions for the users:
Name
Description
View the LPR tab in client applications
Enables the permission to use XProtect LPR features in XProtect Smart Client.
Manage LPR
Enables the permission to:
  • add, import, modify, export, and delete match lists in the Management Client.
  • add and remove license plates from match lists in XProtect Smart Client.
  • remove, disable, and configure existing LPR cameras.
View the LPR node in Management Client
  • add, remove, and configure match lists
  • add, remove, and configure LPR camera
  • add, remove, and configure LPR servers
  • add, remove, and configure license plate aliases.
