Log server
The log server stores all log messages for the entire system in a SQL Server database. This log messages database can exist on the same SQL Server as the management server's system configuration database or on a separate SQL Server. The log server is typically installed on the same server as the management server but can be installed on a separate server to improve the performance of the management and log servers.
