Incident properties (Incidents node)
The following information describes settings that are related to XProtect Incident Manager.
You define all incident properties for your XProtect Smart Client operators on these tabs:
  • Types
  • Statuses
  • Categories
  • Category 1-5
All the incident properties have the following settings:
Name
Description
Name
Incident property names do not have to be unique, but it is an advantage to use unique and descriptive incident property names in many situations.
Description
An additional explanation of the defined incident property. For example, if you have created a category named Location, its description could be Where did the incident happen?
