Get additional licenses
If you want to add or if you have already added more hardware devices, XProtect Interconnect systems, doors or other elements than you currently have licenses for, you must buy additional licenses to enable them to send data to your system:
To get additional licenses for your system, contact your XProtect product reseller
If you have bought new licenses to your existing surveillance system version:
Simply activate your licenses manually to get access to the new licenses. For more information, see Activate licenses online or Activate licenses offline.
If you have bought new licenses and an upgraded surveillance system version:
You receive an updated software license file (.lic) with the new licenses and the new version. You must use the new software license file during the installation of the new version. For more information, see Upgrade requirements and considerations
