Generic Events tab (options)
On the Generic Events tab, you can specify generic events and data source related settings.
For more information about how to configure actual generic events, see Generic events.
Name | Description |
Data source | You can choose between two default data sources and define a custom data source. What to choose depends on your third party program and/or the hard- or software you want to interface from: Compatible: Factory default settings are enabled, echoes all bytes, TCP and UDP, IPv4 only, port 1234, no separator, local host only, current code page encoding (ANSI). International: Factory default settings are enabled, echoes statistics only, TCP only, IPv4+6, port 1235, <CR><LF> as separator, local host only, UTF-8 encoding. (<CR><LF> = 13,10). [Data source A] [Data source B] and so on. |
New | Click to define a new data source. |
Name | Name of the data source. |
Enabled | Data sources are by default disabled. Select the check box to enable the data source. |
Reset | Click to reset all settings for the selected data source. The entered name in the Name field remains. |
Port | The port number of the data source. |
Protocol type selector | Protocols that the system should listen for, and analyze, in order to detect generic events: Any: TCP as well as UDP. TCP: TCP only. UDP: UDP only. TCP and UDP packages used for generic events may contain special characters, such as @, #, +, ~, and more. |
IP type selector | Selectable IP address types: IPv4, IPv6 or both. |
Separator bytes | Select the separator bytes used to separate individual generic event records. Default for data source type International (see Data source earlier) is 13,10. (13,10 = <CR><LF>). |
Echo type selector | Available echo return formats:
Encoding type selector | By default, the list only shows the most relevant options. Select the Show all check box to display all available encodings. |
Allowed external IPv4 addresses | Specify the IP addresses that the management server must be able to communicate with in order to manage external events. You can also use this to exclude IP addresses that you do not want data from. |
Allowed external IPv6 addresses | Specify the IP addresses that the management server must be able to communicate with in order to manage external events. You can also use this to exclude IP addresses that you do not want data from. |
