General Settings tab
Name
Description
Enable
Enable or disable the integrated access control system. If you disable this setting, your XProtect system will no longer receive access control events.
Integrated access control systems are enabled and visible in XProtect Smart Client by default for users with sufficient permissions.
Sometimes, you might need to disable access control events, such as during maintenance, to avoid generating unnecessary alarms.
Name
Add or edit the name of the access control system integration shown in the Management Client and other clients.
Description
Add a description of the access control integration (optional).
Integration plug-in
Displays the type of access control system selected during the initial integration.
Last configuration refresh
Displays the date and time when the configuration was last imported from the access control system.
Refresh configuration
Click this button when you have made configuration changes in the integrated access control system and want to reflect them in XProtect, such as adding or deleting a door.
After you click the button, a summary of the configuration changes from the access control system is displayed. Review the list to ensure your access control system is correctly reflected before applying the new configuration.
Operator login required
If the access control system supports differentiated user permissions, enable an additional login for the client users. If you enable this setting, the access control system will not be available in XProtect Mobile client.
This setting is only displayed if the integration plug-in supports differentiated user permissions.
Potential settings
The following examples of settings might be displayed, depending on the access control system plug-in you're integrating with. The names of the settings and their content are imported from the plug-in.
Name
Description
Address
Enter the address of the server that hosts the integrated access control system.
Port
Specify the port number on the server the access control system is connected to.
User name
Enter the name of the user from the access control system who should be the administrator of the integrated access control system in XProtect.
Password
By default, the password field is hidden. Click the button to enter the administrator's password for the access control system to save. When you save, the password is verified.
