Enable keyframe recording
You can enable keyframe recording for MPEG-4/H.264/H.265 streams. It means that the system switches between recording keyframes only and recording all frames depending on your rule settings.
You can, for example, let the system record keyframes when there is no motion in the view and switch to all frames only in case of motion detection to save storage.
  1. In the Site Navigation pane, select Devices.
  2. Select the relevant device in the Overview pane.
  3. On the Record tab, select the Record keyframes only check box.
    Enabled option for Record keyframes only.
  4. Set up a rule that activates the function, see Actions and stop actions.
