Enable/disable privacy masking
The privacy masking feature is disabled by default.
To enable/disable the privacy masking feature for a camera:
  1. In the Site Navigation pane, select Devices.
  2. Select the relevant camera device in the Overview pane.
  3. On the Privacy masking tab, select or clear Privacy masking check box.
Note
In a XProtect Interconnect setup, the central site disregards privacy masks defined in a remote site. If you want to apply the same privacy masks, you must redefine it on the central site.
