Enable automatic license activation
For easy maintenance and flexibility - and when your organization's policies permit it - Milestone recommends that you enable automatic license activation. Automatic license activation requires that the management server is online.
If you want to know all the benefits of enabling automatic license activation, see Automatic license activation .
  1. From the Site Navigation pane -> Basics node -> License Information, select Enable automatic license activation.
  2. Enter the user name and password that you want to use with automatic license activation:
    • If you are an existing user, enter your user name and password to log into the software registration system
    • If you are a new user, click the Create new user link to set up a new user account and then follow the registration procedure. If you have not yet registered your Software License Code (SLC), you must do so
    The credentials are saved in a file on the management server.
  3. Click OK.
If you later want to change your user name and/or the password for automatic activation, click the Edit activation credentials link.
