Enable and disable motion detection
Specify the default setting of motion detection for cameras
  1. On the Tools menu, click Options.
  2. On the General tab, under When adding new camera devices automatically enable, select the Motion detection check box.
Enable or disable motion detection for a specific camera
  1. In the Site Navigation pane, select Devices and then select Cameras.
  2. Select the relevant camera in the Overview pane.
  3. On the Motion tab tab, select or clear the Motion detection check box.
Important
When you disable motion detection for a camera, motion detection-related rules for the camera do not work.
