Edit settings for a selected storage or archive
To edit a storage, select its recording database in the Recording and archiving configuration list. To edit an archive, select the archive database.
Click the Edit Recording Storage button
located below the Recording and archiving configuration list.Either edit a recording database or edit an archive.
Note
If you change the maximum size of a database, the system auto-archives recordings that exceed the new limit. It auto-archives the recordings to the next archive or deletes them depending on archiving settings.
