Delete recordings
  1. In the Site Navigation pane, select Devices.
  2. Select the relevant device in the Overview pane and select the Recording tab.
  3. Click the Delete All Recordings button to delete all recordings for the device or device group.
This method can only be used if you have added all devices in the group to the same server. Protected data is not deleted.
