Define public address and port
Important
If you need to access the VMS with XProtect Smart Client over a public or untrusted network, Milestone recommends that you use a secure connection through VPN. This helps ensure that communication between XProtect Smart Client and the VMS server is protected.
You define a recording server's public IP address on the Network tab.
Why use a public address?
Clients may connect from the local network as well as from the Internet, and in both cases the surveillance system must provide suitable addresses so the clients can get access to live and recorded video from the recording servers:
  • When clients connect locally, the surveillance system should reply with local addresses and port numbers
  • When clients connect from the internet, the surveillance system should reply with the recording server's public address. This is the address of the firewall or NAT (Network Address Translation) router, and often also a different port number. The address and the port can then be forwarded to the server's local address and port.
  1. To enable public access, select the Enable public access check box.
  2. Define the recording server's public address. Enter the address of the firewall or NAT router so clients that access the surveillance system from the Internet can connect to the recording servers.
  3. Specify a public port number. It is always a good idea that port numbers used on the firewall or NAT router are different from the ones used locally.
Note
If you use public access, configure the firewall or NAT router so requests sent to the public address and port are forwarded to the local address and port of relevant recording servers.
Assign local IP ranges
You define a list of local IP ranges which the surveillance system should recognize as coming from a local network:
  • On the Network tab, click Configure
