Create day length time profiles
  1. Expand the Rules and Events folder > Time Profiles.
  2. In the Time Profiles list, right-click Time Profiles, and select Add Day Length Time Profile.
  3. In the Day Length Time Profile window, refer to the properties table below to fill in the needed information. To deal with transition periods between lightness and darkness, you can offset activation and deactivation of the profile. The time and the name of months are shown in the language used your computer's language/regional settings.
  4. To see the location of the entered geographic coordinates in a map, click Show Position in Browser. This opens a browser where you can see the location.
  5. Click OK.
Day length time profile properties
Name
Description
Name
The name of the profile.
Description
A description of the profile (optional).
Geo coordinates
Geographic coordinates indicating the physical location of the camera(s) assigned to the profile.
Sunrise offset
Number of minutes (+/-) by which activation of the profile is offset by sunrise.
Sunset offset
Number of minutes (+/-) by which deactivation of the profile is offset by sunset.
Time zone
Time zone indicating the physical location of the camera(s).
