Create an archive within a storage
A storage has no default archive, but you can create archives as needed.
Select the relevant storage in the Recording and archiving configuration list.
Click the
button below the Recording and archiving configuration list.In the Archive Settings dialog box, specify the required settings (see Archive Settings properties).
Click OK.
