Create an archive within a storage
A storage has no default archive, but you can create archives as needed.
  1. Select the relevant storage in the Recording and archiving configuration list.
  2. Click the Create_an_archive_within_a.jpg button below the Recording and archiving configuration list.
  3. In the Archive Settings dialog box, specify the required settings (see Archive Settings properties).
  4. Click OK.
