Create a report of your privacy masking configuration
The devices report include information about your cameras' current privacy masking settings.
To configure a report:
  1. In the Site Navigation pane, select System Dashboard.
  2. Under Configuration Reports, select the Devices report.
    An arrow pointing to the Devices check box in the Configuration Reports pane.
  3. If you want to modify the report, you can change the front page and the formatting.
  4. Click Export, and the system creates the report as a PDF file.
For more information about reports, see Print a report with your system configuration.
