Cardholders tab
Use the Cardholders tab to review available information about cardholders in the access control system.
Name
Description
Search cardholder
Type a cardholder's name. If the name exists in the system, it will appear in the list.
Name
Lists the names of the cardholders retrieved from the access control system.
Type
Lists the type of cardholder, for example:
  • Employee
  • Guard
  • Guest
If your access control system integration allows adding and deleting image files in XProtect, you can upload images to cardholder profiles. This functionality is useful if the access control system integration does not store any existing cardholder images already.
Not all access control systems support adding cardholder pictures through XProtect.
Name
Description
Select picture
Specify a path to a file with an image of the cardholder. This button is hidden if the integrated access control system manages the images and does not allow image changes in XProtect.
  • You can use files in the .bmp, .png, and .jpg formats.
  • Images are resized to maximize the view.
  • Milestone recommends that you use a square image.
Delete picture
Click to delete the picture. If the cardholder also had a picture in the integrated access control system, this picture will be shown instead.
