Back up system configuration with scheduled backup
From Windows' Start menu, launch Microsoft® SQL Server Management Studio.
When connecting, specify the name of the required SQL Server. Use the account under which you created the SQL Server database.
Find the SQL Server database that contains your entire system configuration, including event server, recording servers, cameras, inputs, outputs, users, rules, patrolling profiles, and more. The default name of this SQL database is Surveillance.
Make a backup of the SQL Server database and make sure to:
Verify that the selected SQL Server database is the correct one
Verify that the backup type is full
Set the schedule for the recurrent backup. You can read more about scheduled and automated backups on the Microsoft website
Verify that the suggested path is satisfactory or select alternative path
Select to verify backup when finished and to perform checksum before writing to media
Follow the instructions in the tool to the end.
