Axis One-click Camera Connection (Remote Connect Services node)
These are the Axis One-Click Camera connection properties.
Name | Description |
Camera password | Enter/edit. Provided with your camera at purchase. For further details, see your camera's manual or go to the Axis website. |
Camera user | See details for Camera password. |
Description | Enter/edit a description for the camera. |
External address | Enter/edit the web address of the ST server to which the camera(s) connect. |
Internal address | Enter/edit the web address of the ST server to which the recording server connects. |
Name | If needed, edit the name of the item. |
Owner authentication key | See Camera password. |
Passwords (for Dispatch Server) | Enter password. Must be identical to the one received from your system provider. |
Passwords (for ST server) | Enter password. Must be identical to the one entered when the Axis One-Click Connection Component was installed. |
Register/Unregister at the Axis Dispatch Service | Indicate whether you wish to register your Axis camera with the Axis dispatch service. Can be done at time of setup or later. |
Serial number | Hardware serial number as specified by the manufacturer. The serial number is often, but not always, identical to the MAC address. |
Use credentials | Select the check box if you decided to use credentials during the installation of the ST server. |
User name (for Dispatch Server) | Enter a user name. The user name must be identical to the one received from your system provider. |
User name (for ST server) | Enter user name. Must be identical to the one entered when the Axis One-Click Connection Component was installed. |
