Audio messages tab (options)
On the Audio messages tab, you can upload files with audio messages that are used for broadcasting messages, triggered by rules.
The maximum number of uploaded files is 50 and the maximum size allowed for each file is 1 MB.
Name
Description
Name
Provides the name of a message. You enter the name when you add a message. To upload a message to the system, click Add.
Description
Provides a description of the message.
You enter the description when you add a message. You can use the description field to describe the purpose or the actual message.
Add
Lets you upload audio messages to the system.
Supported formats are standard Windows audio file formats:
  • .wav
  • .wma
  • .flac
Edit
Lets you modify the name and description, or you can replace the actual file.
Remove
Delete the audio message from the list.
Play
Click this button to listen to the audio message from the computer that runs the Management Client.
To create a rule that triggers playback of audio messages, see Add rules.
To learn more about actions in general that you can use in rules, see Actions and stop actions.
