Add Matrix recipients
To add an existing Matrix recipient in Management Client:
  1. Expand Clients, then select Matrix.
  2. Right-click Matrix Configurations and select Add Matrix.
  3. Fill out the fields in the Add Matrix dialog box.
    1. In the Address field enter the IP address or the host name of the required Matrix recipient.
    2. In the Port field enter the port number used by the Matrix recipient installation.
  4. Click OK.
You can now use the Matrix recipient in rules.
Note
Your system does not verify that the specified port number or password is correct or that the specified port number, password, or type corresponds with the actual Matrix recipient. Make sure that you enter the correct information.
