Add and configure an external IDP
In Management Client, select Tools > Options and open the External IDP tab.
In the External IDP section, select Add. Note that only one external IDP can be added.
Enter the information for the external IDP. For more information about the information that is required, see External IDP tab (options).
For information about how to register which claims from the external IDP that you want to use in the VMS, see Register claims from an external IDP.
