Add a preset position (type 1)
To add a preset position for the camera:
  1. In the Site Navigation pane, select Devices and then select Cameras.
  2. Select the relevant PTZ camera in the Overview pane.
  3. On the Presets tab, click New. The Add Preset window appears:
    Preview of the Add Preset window.
  4. The Add Preset window displays a live preview image from the camera. Use the navigation buttons and/or sliders to move the camera to the required position.
  5. Specify a name for the preset position in the Name field.
  6. Optionally, enter a description of the preset position in the Description field.
  7. Select Locked if you want to lock the preset position. Only users with sufficient permissions can unlock the position afterwards.
  8. Click Add to specify presets. Keep adding until you have the presets you want.
  9. Click OK. The Add Preset window closes, and adds the position to the Presets tab's list of available preset positions for the camera.
