XProtect LPR admin manual
What's new?
Version2026 R2
LanguageEnglish
In XProtect LPR 2025 R3
Due to the ongoing LPR engine enhancements, the parameter Stop recognition above has been deprecated. It is no longer available in the LPR camera settings.
In XProtect LPR 2025 R2
Added vehicle properties to match lists
In 2025R1, we introduced vehicle properties to XProtect LPR. In 2025R2, you can now add these vehicle properties to match lists.
For more information, see Match lists.
Added guidance and best practices around the use of country modules
To provide guidance around the use of country modules in XProtect LPR, we've added a new section explaining what country modules are, the types of country modules we have, what to use them for, and some best practices for how and when to use the different types of country modules, including examples.
For more information, see Country modules.
In XProtect LPR 2025 R1
Added vehicle properties to searches and in LPR match lists
Milestone has added vehicle properties to XProtect LPR. Users of XProtect® LPR in XProtect Smart Client can refine their searches by specifying detailed vehicle properties, such as the make, model, and color of the vehicle.
Users can specify and adjust what vehicle properties they need in the searches on the built-in Search tab in XProtect Smart Client or in match lists on the LPR tab.
Find a full overview of vehicle properties and their associated values under Overview of vehicle properties.
