XProtect LPR admin manual
Select snapshots
Version2026 R2
LanguageEnglish
You added snapshots during the initial setup in the Add LPR camera wizard that helped set up the recognition accuracy. You can add more snapshots anytime to improve the recognition accuracy.
Follow these steps to add and validate snapshots:
  1. Select the relevant camera and go to the Recognition settings tab. Click Snapshots.
  2. Take snapshots from live video or import them from an external source. Click Next.The system analyzes the snapshots for the selected camera.
  3. On the next page, review the snapshots. Approve or reject each one.
    • If no license plates were recognized, click Previous and add higher-quality snapshots.
    • If recognition still fails, check your camera’s mounting and configuration settings.
  4. When all snapshots are approved, click Next and close the wizard.
  5. Return to the Recognition settings tab, then click Validate configuration.
