Country modules tab
A country module tells the system how to recognize which license plates come from which countries, states, or regions—based on how the plates look and are structured.
On this tab, select the country modules that you want to use with a specific LPR camera. The list that you can select from depends on:
The modules that you have installed.
Your licenses.
Milestone recommends that you add a maximum of five (5) country modules per camera.
Modules that are already licensed show a check mark in the Licensed column. If you don’t see the country module you need, contact your vendor.
Name | Description |
Select | Click to select or deselect a country module. The list of selected country modules on the right-hand side updates automatically. |
Country Module | Lists the installed country modules. |
Country Code | Letters that identify a country module. |
Licensed | Shows if a country module is already licensed. You can select a licensed country module for as many cameras as you like. |
After changing the settings for your LPR camera, validate your configuration in the tab to check if the system recognizes license plates as well as expected.
