XProtect LPR admin manual
Add a camera dedicated to LPR
Version2026r1
LanguageEnglish
To set up cameras for license plate recognition, you must run the Add LPR camera wizard. It guides you through the main configuration steps and automatically adjusts settings to improve recognition performance.
To run the wizard:
  1. In the Site Navigation pane, select Servers > LPR servers > LPR cameras.
  2. Right-click the server and select Add LPR camera.
  3. Follow the instructions in the wizard:
    • Select the camera you want to configure for LPR.
    • Select which country modules you want to use with your LPR camera.
    • Select snapshots to use for validating the configuration).
    • Validate the result of the snapshot analysis.
    • Select the match lists to use. Use the default selection, if you have not yet created any lists.
  4. On the last page, click Close. The camera used for license plate recognition is displayed in the Management Client. The system has optimizes the recognition settings as a result of your selections.
  5. Select the camera you have added and review its settings. If needed, you can go back and adjust the settings to improve license plate recognition.
  6. In the Recognition settings tab, click Validate configuration.
Note
If you move an already activated camera between two LPR servers, expect a delay of up to one minute before it becomes fully operational. While transitioning between the servers usually takes around 25-30 seconds, larger installations might take longer time to complete, so it's best to plan for a short wait.
