XProtect LPR admin manual
Edit custom fields properties
Version2025r3
LanguageEnglish
You can add a maximum of five (5) columns to your match lists for additional information. You can define the name and number of columns, and the content of the fields.
XProtect Smart Client users can update the information in the columns but not the columns themselves.
Name
Description
Add
Adds a column to the match list. Enter a name for the column.
Edit
Click to edit the name of the column.
Delete
Deletes a column.
Up
Changes the order of the columns.
Down
