Avoid partial recognitions by extending the time span
If parts of the same license plate are being detected as separate, incomplete numbers, first make sure nothing is briefly blocking the camera view—like moving objects or glare.
If the issue continues, you can give the system more time to capture a complete plate. This adjustment can improve the accuracy in detections, but it may delay the recognition results slightly.
To adjust the time span:
In the Site Navigation pane, select Servers > LPR servers > LPR cameras.
In the LPR cameras pane, select the camera you want to modify.
On the Recognition settings tab, click Advanced settings.
In the Time span for avoiding partial recognitions field, drag the slider to the right. You can give the system up to five (5) extra seconds to capture the best result and ignore partial reads.
