Adjust settings for your LPR camera
The system optimizes the camera’s configuration automatically when you add it using the Add LPR Camera wizard. If you want to make changes to the initial configuration, you can:
Change the name of the server or change server.
Adjust and validate the recognition settings.
Add more match lists.
Enable additional country modules.
