XProtect Incident Manager for users
Delete an incident project
Version2025r3
LanguageEnglish
If you no longer need to keep an incident project, you can delete it. You can't undo the deletion.
  1. Select the Incidents tab.
  2. Select the incident project that you want to delete.
  3. Select Delete and confirm the deletion.
Tip
If you are in doubt about deleting an incident project, you can open it and review its information before deleting it. Also, view one or more video sequences to ensure that you have selected the correct incident project for deletion.
