XProtect Incident Manager for users
Creating incident projects
Version2025r3
LanguageEnglish
There are several ways of creating an incident project. Which one is best depends on the following:
  • When you discover the incident.
  • If you need to solve the ongoing situation on-site and have little to no time to create your incident project.
  • If there are no sequences to add to the incident project.
  • Your personal preference.
Note
If you need the sequences and information in your incident project for a longer time than the retention times your administrator defined for sequences and incident projects, export your incident project and generate a report. See Export an incident project and Create a report with incident project information.
