XProtect Access for users
Change access monitor settings
Version2026r2
LanguageEnglish
In live mode, you can change the settings of your access monitor:
  1. Click Setup and select the access monitor view item you want to modify.
  2. In the Properties pane, click the Access monitor settings button.
  3. In the Access monitor settings window that is displayed, specify the settings and save to return to live viewing.
