XProtect Access for users
Add access monitors to views
Version2026 R2
LanguageEnglish
You must set up an access monitor to use access control functionality in XProtect Smart Client. An access monitor is a view item that enables you to carry out access control-related actions in XProtect Smart Client.
  1. In setup mode, select a view you want to use for access monitoring.
  2. In the System overview pane, click Access monitor and drag it to a view item.
  3. In the Access monitor settings window that is displayed, specify the settings. When you have selected a door, you can keep the default settings or adjust them if needed.
  4. Click OK. The access monitor is added to the view.
    When an access control incident that triggers an event occurs, it is displayed on the right side of the view item.
