Monitor and control door states
The Doors list displays the doors, access points, and other access control units in each access control system, plus their current state. The list can be useful if you need to know the state of a specific door or similar.
You can filter on the doors list in several ways to display the data you're interested in. Any filters you apply are immediately reflected in the list.
On the Access control tab, select Doors list.
Click any filter at the top of the list and specify the criteria.
You can combine the filters or enter your criteria in the search field to search for doors or right-click a door or a state within the list and filter using that value.
Another way to monitor the door states for your surveillance area is by adding doors to maps.
