XProtect Access for users
Manage cardholder information
If your integrated access control system is configured to support this feature, you can open a webpage that displays a cardholder's record. On that page, you can carry out tasks such as managing user settings or viewing additional cardholder details.
Provided that the integrated access control system supports deep linking, the following prerequisites exist for the access control system:
  • It must include a web client.
  • It must support deep links.
To manage cardholder information:
  1. On the Access control tab, select the Cardholders list.
  2. Search for a cardholder and select the person from the list.
  3. On the right-hand side, below the cardholder information, you can click a link to a webpage that opens and displays the available cardholder information. Depending on the integrated access control system, more links might be supported. You might need to add your user name and password again.
  4. You can edit details, including cardholder information and access permissions.
  5. Close the webpage and return to XProtect Smart Client.
