XProtect Access for users
Investigate cardholders
The Cardholders list contains a list of the cardholders and their details. The cardholders list can be based on data from each integrated access control system.
You can filter the cardholders list in different ways to make it display only the data you're interested in. Any filters you apply instantly update the list.
  1. On the Access control tab, select Cardholders list.
  2. Click the filter at the top of the list to specify the access control system you want to investigate cardholders from. You can only work with one access control system at a time.
  3. Combine the filters or enter your criteria in the search field to search for cardholders. Alternatively, you can right-click a cardholder or a type within the list and set the filter using that value.
When you select a cardholder, detailed information about that cardholder is displayed on the right-hand side of the screen. An image of the cardholder and a link to manage the cardholder's record might also be shown.
