XProtect Access for users
Export an access report
On the Access control tab, you can create and export a report of the event list to a PDF file when you are not in live update mode.
  1. Filter or search for the events you want in the report. If the event count is high, refine your search to reduce the number of results.
  2. Click the Access Report button, then fill out the fields. The report contains:
    • Report name
    • Report destination
    • A list of the applied filters
    • A comment field
    • An option to include snapshots.
  3. Click OK and wait until the report is complete.
  4. In the top right corner, click Details, then in the window that is displayed, click Open. The access report opens in PDF format.
