XProtect Access
XProtect Access is an extension of XProtect. If a dedicated XProtect plug-in exists for that access control system, it enables organizations to integrate their access control systems with XProtect.
To use this extension, you must purchase:
One base license for each XProtect system you want to use with XProtect Access.
One door license for each door you want to control through XProtect.
XProtect Access includes:
A shared user interface for access control systems in XProtect Smart Client.
Powerful integration of access control systems.
Live monitoring of events at access points.
Operator-assisted access requests.
Integrations with maps.
Alarm definitions for access control events.
Investigation of events at access points.
Centralized overview and control of door states.
Cardholder information and management.
Whenever a user in XProtect Smart Client takes any access-related action, such as opening a door or denying entry, the system records it in the Audit log.
