Supported features
Video streaming
Codecs: JPEG, MPEG4, H.264, H.265
Streaming modes: RTSP/TCP (interleaved), RTSP/UDP/unicast, RTSP/UDP/multicast, RTSP/HTTP and HTTP, SRTP/RTSPS/UDP,SRTP/RTSPS/UDP multicast, SRTP/RTSPS/TCP (only for JPEG, MPEG4 and H.264)
Note
H.264 streamed over HTTP is supported only in “H.264 Annex B” format, with prefix codes. AVCC and MP4 SRTP/RTSPS/UDP, SRTP/RTSPS/UDP multicast, SRTP/RTSPS/TCP (MPEG-4 Part 14) formats are not currently supported.
Audio streaming
Codecs: G.711, G.721, G.723, G.726, AAC
Streaming modes: RTPS/TCP, RTSP/UDP/unicast, RTPS/UDP/multicast, RTSP/HTTP and HTTP, SRTP/RTSPS/UDP,SRTP/RTSPS/UDP multicast, SRTP/RTSPS/TCP
HTTPS – transferring data and video/audio over secure HTTP (HTTPS) – applicable only when HTTP or RTSP/HTTP streaming modes are selected.
Note
To use secure streaming, HTTPS must be enabled on the device as well. This is usually done through the device’s web page.
