Designed for network and IT systems
From a technical standpoint, Milestone XProtect VMS products are designed and implemented as a regular IT infrastructure system. The product’s system architecture, with a client-server design and management principles, should therefore be very familiar to IT and network administrators.
Use standard IT equipment, configuration options, and protocols:
Standard servers of your choice
Standard storage of your choice; SATA, SAS, SSD, DAS, SAN, NAS, iSCSI, etc.
Standard storage configuration of your choice; RAID 0, 1, 5, 6, 10, etc.
Standard network equipment with configuration and layout of your choice including support for VLAN’s, VPN, and firewalls etc.
Standard certificate-based HTTPS encryption of network communication
Integrates with the standard Microsoft Active Directory
Integrates with OpenID and OAuth2 authentication and authorization
Use standard Microsoft SQL Server for storing the VMS configuration and logs
Wide choice of Microsoft® Windows® operating systems:
Microsoft Windows 10 (64 bit) - Pro & Enterprise
Microsoft Windows 10 (64 bit) - IoT Enterprise LTSB (v1607 or later)
Microsoft Windows 10 (64 bit) - IoT Enterprise (v1803 or later) & IoT Core
Microsoft Windows 11 (64 bit) - Pro & Enterprise
Microsoft Windows Server 2016 (64 bit) - Essentials, Standard & Datacenter
Microsoft Windows Server 2019 (64 bit) - Essentials, Standard & Datacenter
Microsoft Windows Server 2022 (64 bit) - Essentials, Standard & Datacenter
The newest updated list can be found here: System Requirements
Support for cloud hosting and virtualization technology:
Support for VMware
Support for Microsoft Hyper-V
Support for Amazon AWS
Support for Microsoft Azure Virtual Machines
As well as all other virtualization technologies supporting Microsoft Windows operating systems
Easy installation and upgrade:
All XProtect VMS products are offered in fully functioning trial versions. These trial versions can easily be upgraded to paid versions by simply applying a new license file to the running system – No need to reinstall, reconfigure or even restart the VMS
Likewise, XProtect Expert and XProtect Professional+ can easily be upgraded to a more advanced XProtect product by simply applying a new license file to the running system – Again, no need to reinstall, reconfigure or even restart the VMS
Installers for the VMS server components and clients are hosted on the management server for easy download to new computers where VMS components should be installed – No need to manually distribute installers via USB thumb drives
Easy upgrade or addition of new camera drivers via dedicated device packs - No need to upgrade all VMS components and clients to support new camera models or new camera firmware
Flexible deployment that can be scaled over time:
A scalable system architecture. Depending on the requirements, configuration, system size or usage, everything can be run on a single server, or components can be distributed over multiple servers. This provides everyone with the option to choose the most cost-efficient hardware and VMS system design that fits their needs, whether the needs are for a small or a large VMS installation.
Support for Milestone Federated Architecture™ to tie related systems together
For more information: White paper - Milestone Federated Architecture
Support for Milestone Interconnect™ to tie independent systems together
For more information: White paper - Milestone Interconnect
Central management and monitoring:
All VMS management and configuration is done through a Management Client that can be used on any computer, for instance on the IT or VMS administrator’s local workstation. This eliminates the need to access the VMS servers directly to manage the VMS
The XProtect VMS products support definition of an unrestricted number of user roles, each with support for controlling which cameras/devices, functions and features the users in the role can access or administrate
Having the roles defined, users are simply added to the roles they should have in the VMS
Using Microsoft Active Directory (AD), it can be even simpler to manage the VMS users. The reason for this is that AD groups can be used in the VMS roles, which allows management of VMS access by simply assigning users to the right groups in the AD
Built-in server and VMS performance monitoring including email notification on events and failures. Alternatively, or in addition to the built-in monitoring, you can use standard IT tools to monitor the servers, storage, network, etc.
Secure and reliable architecture:
Failover support on management and event servers via:
XProtect Management Server Failover add-on product
Microsoft Windows Server Failover Clustering (WSFC)
Virtualization software like VMware, Microsoft HyperV etc.
Dedicated hot-standby or cold-standby failover recording servers
Certificate based HTTPS encryption of communication between VMS servers and clients, and between recording servers and cameras
Support for separating client network and camera network, thus preventing that users and equipment on the client network get the opportunity to tamper with or hack the cameras or interfere with video recording
For more information and recommendations on securing and hardening the servers, network, and VMS installation:
Predictable cost:
Transparent and simple license structure
Base license:
The base license unlocks all software functionality and allows the software to be installed and used on multiple sites when owned by the same legal entity
Device license:
For single and multi-sensor cameras, a device license typically allows use of all video channels in the device. For video encoders, NVR’s, DVR’s etc. a device license may be needed per each channel that is enabled
For precise information on supported devices and the device license required: Supported Devices
Milestone Care Plus is mandatory for XProtect Corporate and XProtect Expert for the first year. Milestone Care Plus gives access to new product releases for free
Milestone Care Plus is optional for XProtect Professional+
No license cost on number of recording servers used
No license cost on storage amount used
No license cost on number of clients used
No license cost regardless of video codec used – for instance, H.264, H.265 etc.
Predictable maintenance cost as the system runs on standard IT equipment
