OpenTelemetry Audit Logs
Troubleshooting
Information about the status of the OpenTelemetry configuration can be found in the log files of each one of the services that support OpenTelemetry.
WARNING - No logger configuration found for Server. Returning default factory (NullLoggerFactory).
Once configured and enabled, a set of log lines will be written in the services log files describing the state of the configuration similar to:
Errors can also be found in these files, and contain descriptive information that can help resolve them, like:
